The Sony Extra Bass Headphones Model: MDR-XB450AP, are a high end pair of headphones that are manufactured by Sony. Features an omni-directional microphone for Bluetooth capabilities.
19вопросов Показать все
My headphone's wire broke
Actually the part which connects the wire that broke last night is there any way to fix it??
Plz plz help
Это хороший вопрос?
Оценка 1
1 Комментарий:
Please post images. You have bluetooth capable headphones. Are you referring to a charge cable? or the 3.5mm jack type wire?
из
Добавить комментарий
2 Ответов
[] can you fix it? Yes of course. It should be easy. Much easier if you know how to solder, otherwise you would have to twist the wires to connect the broken ones.
kindly post a picture here and I will give you step by step instructions on how to fix it.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I have a problem with them too. the part where the wire from both the speakers meet is cut and I don't know which wire to solder with the right color. if you know which color goes to which that would be appreciated.
из
I attached A photo of my broken headphone
Update (06/27/2019)
Attaching the photo of my broken headphone
Оценка 0
Добавьте свой ответ
Alvin Mathew будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 1,654
