Why does my display go off when opened more than 45 degrees?
Why does my display go off when opened more than 45 degrees? Shining light on screen shows images.
Это хороший вопрос?
Это хороший вопрос?
you probably have damaged backlight cable. try to open your screen assembly and have a look on connections.
as you did not provide model number, i cannot look up the right guide. you'll have to do it yourself...
Был ли этот ответ полезен?
inverter cable
Similar problem with my 14" G4 powerbook except that its back light dims badly when the screen is opened more than a couple inches (30 degrees). Seems like a loose connection or something. I don't know how to check the backlight cable or open screen assembly.
john, if you need help with your computer, it is best to ask your own question. Click on the link on the right side of this page "Ask a question" and give as much information as possible. There are lots of Mac Gurus on here that can help you with that. Right now it looks like you are answering a question. Thanks.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 501
