Why won't the Oontz Angle 3 speaker connect with PC Bluetooth?
The connection worked previously, I have no idea what has changed.
The PC sees the speaker, but the speaker doesn't play.
I tested the PC with AUX cable which works, I am also able to connect the speaker through Bluetooth on my phone.
I have checked all my PC settings and have no idea what else to look.
Help!
Это хороший вопрос?
This happened to me, too, recently. Just after updating my PC, the Oontz Angle 3 would only be recognized as "Bluetooth Headset" and would fail to connect.
I have obviously removed the Oontz Angle Device 3 and tried to reconnect it.
I have also deleted/reinstalled any/all Bluetooth drivers on my computer.
The Oontz connects perfectly well on my iPhone, however.
What is going on?
из Ben S
I still don't know the reason, but it worked for me when I uninstaled the speaker and installed it again. It happened to me a few times the Bluetooth connection didn't work without this "manual reset". So, go to devices, installations, and remove and then again add the speaker. I hope this helps you too!
из Kristina Bogataj
