Why does my tablet keep freezing?
Hi my tablet keeps freezing, I have tried a factory reset but that still hasn't helped. Freezing seems to occur randomly . Usually it's when I try to play a game but it's also froze when I'm doing nothing. Once the tablet is froze I have to hold the power button down to get it to restart and it occasionally hangs on the Samsung logo, which requires me to hold power button again and again until it decides to boot . My battery is pretty poor and the tablet spends most of its life on charge. Is it possible this is a battery issue or something else?
Thanks
Это хороший вопрос?
Оценка 0
7 Comments:
its not a battery issue I would recommend to get it checked somewhere
из
Not sure what else it could be other than the battery, I've done a hard reset so it's not the software,it's not water damaged or anything .anything else I could check?
из
Did you just factory reset your phone through Settings or flashed the ROM? If not, try it.
из
Just factory reset. I will try flashing today
из
So I have flashed stock firmware and still freezing, I have noticed that it only really freezes after the tablet has been charging. Sounds like maybe the tablet is overheating while charging maybe? Any ideas?
из
Показать 2 больше комментариев
Добавить комментарий
1 ответ
Try freeing up space that should speed it up.
Был ли этот ответ полезен?
Оценка 0
2 Comments:
I don't need it to speed up, just to stop freezing
из
Buy a SD card which will give you more hard drive space.
из
Добавьте свой ответ
John будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 14
За всё время: 5,240
