Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
iPhone 6 won't hold a charger after battery replacement
I bought the ifixit iPhone 6 battery repair kit and successfully installed the new battery. My issue is my phone still dies when it reaches around 50% battery life. When i plug it in and it boots back up the battery shows 1-6% on it. This only started being an issue after about a month of using the new battery, although the new battery never let me use my phone to 1%, always dying around 10-15% from the start.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
It could be a poor quality replacement battery. To be certain, use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). It will tell you what the health of the battery is. Anything less than 80% of design capacity will require replacement. After testing the battery, I would contact iFixit Support to see about a replacement.
It is possible that you have an issue on the logic board so if another replacement battery behaves the same way, that is where I would look for the problem.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
CoconutBattery says "perfect" and its at 100% capacity (1751/1751 mAh). Is replacing a logic board a complicated/cost effective fix and or even worth doing?
из
The logic board is the phone. You may as well replace the phone. I am suggesting a micro-soldering repair.
из
maybe the battery is not in good condition.
Оценка 1
Добавьте свой ответ
Zachary Kessler будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 120
