LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146вопросов Показать все
I dropped my phone and now the power button doesn't work.
My phone fell face down. the screen worked fine, but the power button wouldn't work. I could only turn the phone on and off by using the screen. I tried to take the battery out so it would turn off all the way, but now it won't turn back on.
Это хороший вопрос?
Оценка 0
1 Комментарий
Hey check out this fix
Works quickly .
http://dillysano-mymakemoneydiary.blogsp...
из
Добавить комментарий
1 ответ
Выбранное решение
When it impacted the ground it could have severed the cable going to the power button. You will have to replace that if you want to fix the powering off problem. Sorry i don't have any other options but thats all you can really do in this case.
Good thing is that cables cost very little so thats a plus.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
thank you. I was thinking that might be the only option.
из
how much tho?
из
Добавьте свой ответ
ash будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 36
За всё время: 4,602
