The Black and Decker is a cordless household drill that can be found by the serial no. LDX 120C
4вопросов Показать все
Black and Decker 20 volt Battery wont charge
I have 2 Black & Decker 20 volt "Matrix" batteries.
During another household project, I used the battery as a power supply for something else. Low draw, was not getting hot. Discharged down to 17 volts. Now when I plug it in, charger just shows "bad battery".
Another just shows "bad battery" on the charger when I plug it in. It's practically new but I have no insight on that one.
Anyone familiar with how these opperate that might have a fix at least for the first one? My suspision is that somehow the battery knows it was used for something it should not have been. If that's the case...can it be reset?
Same problem with older 18 volt "Firestorm" battery. This could be age...but every battery (3) shows bad?
Это хороший вопрос?
Оценка 1
2 Комментариев
Jason Cox do you have a model number for either the battery or the drill/driver itself?
из
Yes I'm wanting to know can the 20 volt be made to charge again
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi Jason. Sometimes you can revive a "bad battery" by manually charging the battery with a variable voltage power supply. In this case you have a 18.5v battery which is operating at 17v. You know that the battery pack is composed of at least (5) 18650 lithium ion cells in series. Voltage adds in series. 18650 cells have a nominal voltage of 3.7v (3.7*5 = 18.5v). Most 18650 cells have a charging voltage of 4.2v. If you charge the pack at 21v (4.2*5=21) or just slightly higher (~21.5v), you should be able to boost the nominal voltage of the pack closer to the desired 18.5v. I have found that manually charging a "bad battery" with a variable power supply for 10-15min will bring up the pack to a level where the genuine drill power supplies will be able to recognize and charge the battery pack again.
Good luck.
Был ли этот ответ полезен?
Оценка 5
3 Комментариев:
I have NO IDEA what your talking about. I don't want to know how its made I just want it to work!
из
I dont know why you would be so rude.
из
its one thing to be rude and another to be downright stupid!! this is the type of person why they invented troubleshooting guides that start out with "is the unit plugged in"
из
I have no experience with Black and Decker batteries, but have had DeWalt batteries do that. I would take the bad battery and place a penny in each of the power terminals. See pics. Take the good battery and make SURE to connect (+) to (+) and (-) to (-). Connect only for several seconds. Place bad battery on the charger immediately. I have revived several batteries in this manner. Please use caution when using this procedure. As a precaution make sure to do this outside in case of fire.
Оценка 5
5 Комментариев:
Wow! This worked perfectly! Thank you!!!!!!!
из
I purchased a Black & Decker battery two months ago, and it suddenly died. I tried your method, and It works! I don't know how, but it just works! Thanks!
из
I have a black and decker 20 v lithium ion drill battery will not charge the red light is flashing on the charger I have only used the drill once about one year ago how to make it charge?
из
Make sure you hook + to + and - to - it shows on batteries - Worked for me
из
That is incredible. I wasn't sure it would work. Thank you for sharing this trick!
из
Добавьте свой ответ
Jason Cox будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 120
За последние 30 дней: 414
За всё время: 16,392
