Samsung Galaxy S7 (SM-G930, SM-G935) — смартфон седьмого поколения линейки Galaxy S, анонсированный компанией Samsung Electronics 21 февраля 2016 года на MWC в Барселоне[
359вопросов Показать все
Having Pink lines on the right side of the screen?
I am up for replacing the outer glass if that is all that is needed. But if it is the digitizer, then it seems to cost a lot more?
What needs to be replaced in this condition?
Thanks in Advance.
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Выбранное решение
Display assembly needs to be replaced, gone faulty.
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
When you say display assembly, what does it mean? Do you have a link to what needs to be bought? I would really appreciate it.
из
So just replacing the front LCD glass wont fix the issue?
из
Nope, as it's just a piece of glass.
Here is a link to the part:
Galaxy S7 Edge Screen
из
Im not sure but it sounds like the display needs to be replaced.
Оценка 0
I have seen other methods and some owners say it comes and goes or by pressing on the top off screen. As having many years as a field service tech and dealing with connections it would be a matter of re-seating the ribbon cable connection. e.g. a lg tv that losses wifi just tack back off and dis-conect and re-conect both ends and fixed wifi. LG suggest to take back for repair or replace module. I have done this now on 5 lg tv’s Connectors do become a real problem so any views on a disassemble to this screen ribbon cable thanks.
Оценка 0
1 Комментарий:
Sorry should have checked speeling.
из
Добавьте свой ответ
Ujwal Tamrakar будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,095
