"Unable to join WiFi network" How can I fix this?
So, my iPod Touch 1G just arrived today and for some reason, the WiFi has a weak signal and it says "Unable to connect to the network". Does anyone know how to fix this?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Unplug and plug in router. Move close to the router (try this step first). Restart iPod. If all else fail try full erase.
Update (01/13/2018)
Is the iPod used? Or new? A used iPod might need the Wifi antenna replaced or it could’ve come disconnected. Most of those are little (coax) cables but they look different in a phone or ipod/iPad. I wouldn’t suggest doing this yourself because iPods are the hardest Apple device to get into unless you like soldering. Sorry for the late reply. I hole this helps if you’re still having the problem
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Everything i tried failed, even the reset. What do I need to fix?
из
Добавьте свой ответ
superlions16 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 532
