Phone won't turn on or charge after power outage? Is my phone fried?
Hi.
I had my note 4 charging on a power strip while I slept. During my sleep, a power outage occurred. When I woke up, my phone wasn't turning on even though it was still plugged in. However, there was a red LED light showing on the top left (which means low battery). I took out the battery and put it back in to completely shut down the phone. Plugged the phone back in and the phone did not turn on or vibrate to indicate that the phone was charging. The power strip still works and I tried charging my phone with different charging cables, charging heads, and outlets, it still wouldn't charge/turn on. I even tried everything with a different battery and still didn't work. I tried soft resetting and boot into safe mode, didn't work.
Did the power going back on cause a surge and fried my phone's circuitry?
I don't really want to replace my phone at the moment. What should I do? Can it be fixed? If I need to get it fixed, where would I go to do that?
Thanks.
Это хороший вопрос?
1 Комментарий
I had the same probably but i used a computer charger and it worked until i woke up this morning
из Izzabell Gill
