7.9 inch display iPad Mini, with 16, 32, or 64 GB of storage.
690 Questions Показать все
Why has my ipads screen glitched
why has my ipad minis screen glitched so that the swipe down thing is almost fully down and cant turn it off or open or even swipe it back up
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
Free shipping on orders over $20
Use code BLUEANDBLACK at checkout
1 Ответ
Наиболее полезный ответ
Has the screen been replaced by a mobile phone repair shop? If yes, take it back to them for warranty.
Is there a crack on the glass? If yes, get the screen replaced. If the crack is in the inside layer of the glass it will interfere with the touch screen functionality.
In short, the digitizer touch screen needs to be replaced.
Here is where to buy the part:
iPad mini 1/2 Front Glass/Digitizer Touch Panel Full Assembly
Here is a guide on how to replace it:
iPad Mini GSM Front Panel Assembly Replacement
Hot tip: When lifting up the LCD, use plastic money notes if you have it available, they are great for cutting the adhesive under the LCD. I use that to slide cut the adhesive on the top and side of the screen (Do not do the bottom of the screen as that is where the LCD black ribbon flex is).
iPad mini 1/2 Front Glass/Digitizer Touch Panel Full Assembly Изображение
Продукт
$54,99
Был ли этот ответ полезен?
по рейтингу 2
Добавьте свой ответ
Mythical Kitten будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 28
