it is still heating up and it starts to burn
hello, I just replaced the 470 resistance marked in red circle in the photo, but nothing has changed, it is still heating up and it starts to burn getting brown in the center. My 820 4924 A board does not turn on, nor do I see green or orange light when I connect the charger. Resistance 470 heats up a lot. Someone to guide me?
U7090 desoldered and component around
pin 2 and 4 marked in red circle are short to GND
Update (12/10/2017)
My macbook pro 13 A1502 early 2015, plate 820 4924A does not turn on and when you connect the charger, it does not turn on the green and orange magsafe lights either. Please help. I have noticed that the resistance 470 of the photo is heated
Update (12/10/2017)
Hi, I'm still with the problem. Resistance 470 is R7020 of plate 820 4924 A, replace it and burn again. Lift R7020 and pin 2 is shorted to GND. Inject 8,5v into pin 2 of R7020 to see that it was heating up and U7090 became warm, replace it and it remains the same. Lift components around U7090, PP3V42_G3H is short. At this point I do not know what to do, someone to help me?
Update (12/10/2017)
My MacBook Pro 13" A1502 Early 2015, plate 820 4924A does not turn on and when you connect the charger, it does not turn on the Green and Orange MagSafe lights either. I have noticed that the resistor 470 in the photo is damaged (overheated).
Please help
Update (01/13/2018)
I have replaced the resistance 470 of the photo because it got very hot, it burned the finger, but it remains the same. Any idea what happens?
Это хороший вопрос?
