Won’t go over 2rpm
My 2006 Nissan Altima won’t accelerate over 2RPM, when it goes above that it starts jerking, almost feels like it’s choking. I just changed the Camshaft Sensor because it wouldn’t accelerate when I pressed the gas pedal at all. It now goes, but only until it reaches about 21/2 Rpms. It has a new MAF sensor and just replaced the throttle body sensor. Please help I don’t know what else it could be. I’ve recently learned about something called fail safe mode? Could that be my problem? If so, how do I fix that??
Это хороший вопрос?
6 Комментариев
I would like to know why my nessan quest is smoothering down and fluddering out at opeerating tempture
из selfdavid131
Why can't I get a answer or do you knot know
из selfdavid131
If you don't know the answer my queestion just tell me
из selfdavid131
Try researching on nissan forums...if you have cleared the codes and gone through the possible usual culprits i suspect it could be a clogged catalytic converter...read this link....
http://x.nissanhelp.com/forums/quest/112...
из john cordey
2003 murano revs up in park but wont when put into drive or reverse. what do you think it may be?
из Eddie jimmerson
Показать ещё 1 комментарий
