The fifth-generation Elantra debuted at the 2010 Busan International Motor Show in April 2010. The fifth-generation Elantra (2010-2015) added a two-door coupe variant in addition to the standard four-door sedan model. These Elantra vehicles included six-speed automatic or manual transmissions.
Where is the camshaft positioning sensor located 1.8L
hi, can someone let me know where this is? 2011 Elantra 1.8L
thank you
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
Наиболее полезный ответ
It is in the front of the engine, down low, just to the right (as you are facing the car from the front) of the oil filter.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
This is erroneous! This is the location for the crank sensor.
из
No it's not that the crank sensor can sensor is on top of motor.
из
@rnps old question and just to clarify. The camshaft position sensor is (are since we do not know if this is a 1.8L DOHC engine which would have two) located under a cover on the TOP right of the engine.
image credit goes here
Hopefully you got this fixed within the last 4 years :-)
Счет 1
این سنسور روی سر سیلندر سمت چپ خودرو و در انتهای میل سوپاپ قرار گرفته
Счет 0
Добавьте свой ответ
Robin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 39
За последние 30 дней: 158
За всё время: 6,644
