Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Replacement home button doesn't work
I replaced a iPhone 6 screen & the screen/camera/Speakers are all functional but the home doesn't work at all - nothing. My client came to me with out a home button so I cannot test the original. Is the new button defective or is the software glitching out because it hasn't had a home button in a while.
Это хороший вопрос?
Оценка 1
3 Комментариев
A replacement home button should function the same as a regular home button with one exception-fingerprint ID will not work. As far as glitching? A hard rest should solve the problem. Ensure the replacement is for the six.
из
Im getting no functionality at all - I can't do a hard reset without a home button
из
You can do a hard reset if you turn on Accessibility. It will place a home button on your screen. Then just find the option to restart the phone.
из
Добавить комментарий
4 Ответов
Выбранное решение
I would guess the home button to be the defective part.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I will change it out and see. will update. Thank you
из
Наиболее полезный ответ
Could be homebutton, but could also be the longflex running along the screen
Оценка 2
4 Комментариев:
The screen is brand new would that make the new screen defective?
из
its not the actual screen but the metal plate with the ribbon thats attached to the back of the lcd
из
What Daniel said. If it came with the screen, then even higher chance that it does not work as it is likely a cheap part
из
The button was defective - replaced the button (again) and it was fine
из
Touch ID isn’t functional after an screen repair if the home button is replaced.
Оценка 0
1 Комментарий:
I’m not looking to use Touch ID - just use the button for its other functions
из
ensure the cable on the thermal plate is working, try another cable-ensure the socket where the home button is plugged into isn't damaged- try a replacement home button know to work with the iphone six remember the touch id will not work -all other functions should.
Оценка 0
Добавьте свой ответ
jeanise будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,104
