Вопрос закрыт
I dismantled iPod's screen and Ribbon is separated
so . what i should do ?
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
if it is torn you should get a new screen/ribbon assembly,if it is still attached to the screen just plug it back in
Update
if it is plugged in correctly and still doesnt work,recheck the ribbon for damage,if it looks ok you may have a faulty digitizer,you could also try resetting or restoring the ipod manually or through itunes
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
good .
but if lcd itself damaged ,can i fix it with myself?
and i want place of possibly damage on digitizer if
you can .
из
it won't to happened by storing .
из
Наиболее полезный ответ
If you are unsure how to reassemble the ribbon, just take a look at iFixit.com's guide on the iPod Touch: iPod Touch 3rd Generation
Оценка 1
1 Комментарий:
but the question is what is how to install it with
ipod .
i tried to install it but it won't .
when i connect it with computer there is sound from
computer and ipod even front panel is separated .
thank other time .
из
i tried to plug it but it won't work .
it is charged at least half of battery before days .
or if my plugging isn't on the right way please give my the right way .
Оценка 0
1 Комментарий:
any answer ?
из
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,153
