The 99% charge is nothing, happens on laptops as well, it has to do with battery health and a variety of factors that are used into calculating battery percentage.
What they most likely meant, is a fake AC Adapter, that thing you plug into the wall.
I've used cheap chinese ones before, and the screen would become less accurate. It has to do with the amount of noise emitting from the charger. Let me tell you, anything that is suppose to be emiting a DC current and is emitting some AC, voltage spikes and the such, with it which isn't something you want to deal with in your circuits.
I got a refund for the AC adapter and got a OEM apple charger, and like magic my screen works perfectly while its being charged.
Also, the iPhone is rated to handle up to 1 Amp at 5 Volts, most chargers such as standard usb charger uses 500 milliamps(mA) which is completely fine (just takes longer to charge). Usb chargers are also in a computer that generally speaking has a well built power supply that provides a very steady DC current.
Having less current is fine, it charges slower, having to little voltage causes irregularities and having spikes or two much of either current or voltage will burn out an electrical device generally.
That chinese 1-3 dollar iPhone adapter on the other hand, will not. Not all AC usb adapters are built the same, believe me I burnt out an old windows mobile phone back in the day to prove it.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
2 Комментариев
Did they actually use the phrase 'fake power'? That's a great indicator of their expertise, right there.
из Kyle Wiens
Yeah I also had problem with third party chargers. One moment it was nearly full and five minutes later it was nearly empty!!
из Martin
