PS3 doesn't boot, no video, green light
My PS3 60GB (CECHE01) recently stopped booting. I tried two new sets of cables, thinking it was my TV, but no luck. Next, I tried to access the Safe Mode/recovery menu, but still saw no output on the screen. I also tried Safe Mode on an old, composite input TV to rule out my primary TV—no love there either.
A controller connected to USB will not register; it just blinks all four LEDs slowly. It shows the same symptoms when connected with component and old-school composite cables. I have no HDMI available to test.
The green light is on, there's no "yellowish" light of death, and the HDD access light will blink once at boot, then stays off.
The HDD doesn't have any unusual noises (clicking, voice coil dead, etc.).
Since I can't even get into Safe Mode, does this mean it's motherboard or power supply?
Это хороший вопрос?
have you had any luck with it sagamore? im in the same boat
из Callum T
Hey Tom!
Sorry for the delay. I ended up sending it back to Sony for the $129 special. They shipped me out a new one. I suspect it is similar to the ylod, and if you have a hotplate ro reflow rig, you might be able to get whichever chip was loose reconnected, but I wan't set up for that.
из Sagamore
I have the same problem
из Chris F
I'm having the same problem after returning from a plane trip. I suspect my luggage with my PS3 got knocked around pretty good in checked baggage.
из jbb942000
My ps3 slim 160 gb started freezing then it got worst and worst then one day it just shut down and there was no light. then I clicked the power botton then the red came on then I did it again then it turn green but their was nothing on my TV screen then it shut off again.from thet day it kept on doing the same thing.I opened it and cleaned it and it didn't work and the fan and everything is OK but it won't stay on and display pixies in the sceen
из Justin gibbs
Показать 9 больше комментариев
