Repair guides for Dell Inspiron laptops. A line of mid-level Dell laptop computers.
1402вопросов Показать все
Home wifi says “no internet, secured”
So my home wifi works for all of my family’s devices except for mine. When I connect, it says “No Internet, Secured”. This has happened before and after about a month or so I think it just resolved itself. But I need my laptop for school and have tried almost everything. I forgot all networks, uninstalled adapters that many said were causing the problem, and did a total networking reset. Nothing has worked. Any ideas?
Это хороший вопрос?
Оценка 0
6 Комментариев
Was this laptop given to you by your school or is it a personal computer?
из
It is a personal computer
из
What type of laptop is it? (model #?)
из
Inspiron 15 3000
из
Spill anything on it ever? or drop it? recent repairs? etc.?
из
Показать 1 больше комментариев
Добавить комментарий
4 Ответов
Выбранное решение
The way to do a total network reset is with the netsh int ip reset command from an administrative command prompt, or you can do it through the graphical interface. Details at https://support.microsoft.com/en-gb/help... - is this what you did?
A few months ago I had a similar case. A friend's new-ish laptop (Toshiba, I think) kept doing something similar - it wouldn't work with her home WiFi but when she brought it round here it was fine. I replaced the WiFi card with another I had lying around and I think she's been ok since.
I'm not familiar with your particular model of laptop, but it may be that you can easily access the WiFi card by removing a service cover on the bottom (which also gives you access to the RAM). On cheaper consumer-grade laptops it may be a case of slightly more serious disassembly, but at least Dell tends to be good on service manuals, even if you can't find the guide you need here. But as a quick fix you could try a USB network adapter - you can get them quite cheaply from eBay.
Был ли этот ответ полезен?
Оценка 1
You likely need to update the drivers to your WiFi card.
Go to https://support.dell.com, and enter your service tag number.
It will come up with all the proper drivers you should have.
Install the one for your WiFi.
However, if it says you have an Intel Centrino WiFi, download the latest one from https://downloadcenter.intel.com, as they work better.
_________________
Also, right-click command prompt, and select "Run as Administrator".
In the command prompt, type the following 2 commands, then reboot the computer.
netsh int ip reset reset.txt
netsh winsock reset
Оценка 1
If this happened before and fixed itself, be sure to reboot the router!
Оценка 0
Here is a link to a video that may help you fix your wifi connection problems.
Оценка 0
Добавьте свой ответ
Kaitlin K будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 26
За последние 30 дней: 73
За всё время: 2,361
