The MSI GS60 6QE Ghost Pro 4K is a high performance gaming laptop.
7вопросов Показать все
Laptop Keyboard for MSI GS60 6Q Ghost pro 4K
Hello,
I bought a new keyboard from Amazon, but got stuck after I removed the motherboard. The keyboard for this model is under that metal cover which is connected with many plastic stubs. Have any idea how can I replace the keyboard?
Is this spare replaceable or need to have the whole panel?
Thanks
Это хороший вопрос?
Оценка 3
Комментарии:
I have the same problem. I bought the keyboard but i don’t know how to detach and install it into de laptop.
из
Same problem...
из
Добавить комментарий
1 ответ
Pull the latches gently one by one while pulling the metal plate out once all lathes are removed metal plate will be free. Keyboard is underneath it. Replace and latch the metal piece back and you are done.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
RADU CIUCA будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 10
За всё время: 424
