Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
The Lite Version of Huawei's 2017 P10 smartphone. Released in March 2017 it features a dual rear-camera setup developed in partnership with Leica. Equipped with 32/64 GB storage and in six different finishes. Model number WAS-LX1A.
19вопросов Показать все
Battery percentage stalls when plugged in
Hi,
I recently replaced the LCD assembly on a P10 lite. During the process, I tore open the battery by mistake. No big deal, new battery. After all was done, the phone just wouldn't charge. I tried other batteries and chargers and still nothing. Any idea what went wrong? Could the LCD be the blame?
I have to mention that about a month ago I replaced the LCD assembly on another P10 lite and all went well.
Это хороший вопрос?
по рейтингу 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
At first you can reopen the smartphone and make a double check if the battery is connected correctly. Same goes for the LCD (another issue could be the connection of the charging board to the mainboard - you can check this as well). It also can happen, that you damage the interconnect flex cable between charging and main board, whilst removing the battery, in this case the phone wouldn't charge as well).
Был ли этот ответ полезен?
по рейтингу 1
Добавьте свой ответ
Ciprian R будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 482
