Zeppelin speaker not working. Won’t turn on or show any power
I have a bowers and Wilkins zeppelin. The led doesn’t come on and it shows no indication of power or audio. The lead is fine as it works with another speaker. I have opened it and noticed some discolouration around one of the ceramic disk capacitors could this be the issue? Everything else looks fine.
Thanks!
Update (01/07/2018)
Could this be the issue?
Это хороший вопрос?
16 Комментариев
Same problem , just find out today ! Appreciate someone gives a solution for it
из Joe Xman
Same problem too. Asked B&W who just said it would cost £80 to fix and you have to expect such faults in electrical equipment : but this is the second time the power unit has malfunctioned on this Zeppelin in 8 years!
из Toby Johns
Hello… My Zep. Will go on and work some of the time, and then just shuts off and won’t power up. The red power light will be blank. Then the next day…on again, works…and off again. Is there a recommended service center local in Los Angeles or anywhere trusting to ship to? Please help. I want to keep the unit I love it when its working!
из kazalin
Same problem, No light, Air model 30 pins dock, fuse and capasitors seams fine althow 2 diode's have passages both way, does anyone have a diagram or any suggestions to power it Up.
из mynster
Can u please tell how to open zeppelin as I have same problem.
из Sheetal Patel
Показать 11 больше комментариев
