The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1149вопросов Показать все
Suddenly popping, crackling sound.
I got this Macbook as a leftover from my dad. About one-and-half year has passed.
And now I found my speaker popping some weird sounds. Or you can say, it's the frequently asked crackling sound.
This happens several minutes after I turned on my Macbook. But after I left my Macbook for about 10 - 20 minutes, it doesn't happen again. The crackling sound disappeared for a time.
What do you think about this phenomenon?
Should I ignore it? Or should I go to the Apple Store?
Это хороший вопрос?
Оценка 4
2 Комментариев
I also have this issue, your solutions seems to work, I believe your going to be fine not bringing it to the Apple Store.
из
I am same problem with Macbook 2018
waiting for proper solution
Thanks
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Ive tried fan control, PRAM reset, diagnostics ect and finally gave in...took the macbook apart and saw that there was gritty dust in the fan, flushed it out with isopropanol alcohol and its been running smoothly ever since and the popping sound has gone
Был ли этот ответ полезен?
Оценка 1
Fix the disintegrated voice coil flexi ring with flexi white glue.
Оценка 1
Добавьте свой ответ
Sulthon Hernanda будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 9,807
