MacBook won't turn on After replacing Thermal Paste.
Hi there,
My MacBook Pro Retina 13 inch Late 2013 won't turn on after I changed the thermal paste. I cleaned the CPU with Articleaner, the thermal paste is arctic silver 5. While cleaning, a little bit of the thermal grease and cleaner got around the cpu and motherboard. No cables or any additional hardware has been removed or changed, the CPU has been treated carefully while reapplying and cleaning the thermal paste. The black cover/plastic around the cpu dye was peeling off while cleaning carefully however. The MagSafe Connector gives a green light, which is for me personally an indication that their shouldn’t be any shortage or damage, right? I can’t perform any kind of reset, no smc reset or anything else.
I am so far clueless and don’t know what I can do in order to make the device work again, I hope you guys could help me out with this troubleshoot.
Thanks in advance!
Это хороший вопрос?
1 Комментарий
I did plug in everything appropriately but it still doesn’t work....
из Fer
