Car not reversing after removing battery
My 2003 accura stopped entering reverse after a friend used my battery to help someone. The problem was fixed only for it to resurface again but all other gear selectors are working fine. Advise needed urgently please.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
I would try resetting the car's computer through removing the battery negative terminal for around 10 seconds. If that doesn't resolve the issue, I'd take it in to a mechanic (or auto parts store) to have them check for error codes via the OBD2.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thanks mate it worked once more thanks you are one in a million.
из
Добавьте свой ответ
attom garba будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 95
