The 5th generation BMW 3 Series is based on the E9X platform. The car pictured is a E90 chassis. The E9X chassis was used from 2004-2013 when the F1X chassis was released. When talking about a non-specific chassis, this generation is typically referred to as the E9X chassis since there are multiple chassis for this generation of 3 series, depending on the body style (E90/E91/E92/E93).
28вопросов Показать все
Why is my car rpms fluttering in between 1000 and 1500
I have a 2008 bmw 335i and it is fluttering from 1000 rpm to 1500 rpm
It started after I attempted to clean my intake valves.
Codes are
P1417
P1632
P1638
P11:
P1639
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Have you replaced your spark plugs?
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Before the valve cleaning I replaced spark plugs ignition coils and fuel injectors
из
Ok, well unfortunately that's all I got. I've just had some experience replacing spark plugs that were causing the engine to stutter a bit.
из
Добавьте свой ответ
Melech будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 587
