The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
211вопросов Показать все
Galaxy Note2 (N7100) Running OS 4.4.2. IMEI changed to 00499.
Running OS 4.4.2. IMEI changed to 00499. Sim Card Detected but Not resistered on net problem. Tried several methods without BOX.
Already tried: 1) Modem Install by ODIN, 2)Patched modem Zip install via Bootloader by recovery. 3) EFS backup and restore, 4)tried NV data restore bt EFS professional software not working.
Really really too much stressed on this issue. Need a proper solution.
From Bangladesh
Это хороший вопрос?
Оценка 8
Добавить комментарий
1 ответ
Наиболее полезный ответ
EFS got corrupted / wiped. You'll have to repair IMEI with Z3X box.
There are people out there that can provide the service remotely.
Был ли этот ответ полезен?
Оценка 6
Добавьте свой ответ
Amitave Newaz будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 6,819
