Low Pressure when pulling shot or steaming milk
The pump has been replaced with no improvement. I have flushed the system with vinegar, also no improvement.
At a loss of what to try next.
Это хороший вопрос?
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
Hi Ken, is your steam wand or anything else leaking when trying to pull a shot? If so you'll need to resolve that before the group head will get the full pressure from the pump. If nothing is leaking then I would check to make sure your portafilter basket and group head screen aren't clogged, and perhaps try a slightly coarser grind on your coffee as well. You'll want to avoid using vinegar in the machine as it can reduce the life of the pump; use a commercial espresso machine descaler like Dezcal or Durgol instead.
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 104
