I used 12v adaptor instead of 6v, now it has stopped working.
Hi,
I used wrong 12v adapter instead of 6v in bp monitor, now it has stopped working. What to do now?
Это хороший вопрос?
Hi,
Это хороший вопрос?
Hi,
You most probably have a damaged voltage regulator and / or other input supply voltage components on the monitor's control board.
You will have to open it up and inspect it for any obvious damage.
Post some close up pictures of any damaged areas on the control board (hopefully it will be obvious but perhaps it won't be) and maybe someone here will be able to help.
Here's how to do it.
Был ли этот ответ полезен?
It’s possible it used battery power during the time it worked and due to not getting a charge through the 6v power supply, it’s now drained. Try getting the right power supply and try again.
За последние 24часов: 1
За последние 7 дней: 11
За последние 30 дней: 31
За всё время: 1,970
1 Комментарий
How can I fix my blood pressure monitor
из terry skinner
