Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250вопросов Показать все
ipad 2 update from itunes
When ipad was updating operatting system something.9 the power went out half way through and stopped updating.when i came back to it the screen says itunes,as in connect to, and nothing happens , not even capable of going back to previous version, or restore..ipad is completely nothinged...stuck with a itunes that even when i plug it in to itunes dosnt continue loading the new then operating system...no restore no memory and nothing but sthe itunes connect on the ipad screen...What to do?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
1) first separately download the firwmare from here.
http://www.iclarified.com/8500/where-to-...
2) put your iPad into DFU mode
https://www.theiphonewiki.com/wiki/DFU_M...
3) Download 3utools from https://www.3u.com and install the firmware you installed in step 1.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thank you so much, problem solved, and fixed...marvelous...
из
Try to restore from another computer. Make sure your iTunes is up to date. Good luck
Оценка 0
Добавьте свой ответ
heliosiiii будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 155
