iPhone Got wet, screen faint
I dried the phone out for a while but noticed moisture between the lcd and the outside glass so I took the display assembly off and cleaned all the glass off. When I re-assembled the monitor was very faint, but the phone turned on and worked. Now the monitor won't show anything at all, but the phone still appears in iTunes and I can call it and it will ring. Would replacing the whole display assembly be a solution to this or is there something else that might be causing this to happen?
Это хороший вопрос?
2 Комментариев
Similar problem...not a techie...water (coffee) behind screen,,,do not know how to dissemble..still usable except message key does not
activate...
tried drying holes with dryer..HELP>>>
из starusaaustin
try to clean it properly, using this guide Repairing iPhone Liquid Damage
из oldturkey03
