The Lenovo Yoga 710-14IKB was released August 2016. Model name 80V4. 14" touchscreen convertible laptop by Lenovo.
18вопросов Показать все
Would you guys please do a guide on hinge fix/replacement if possible?
Seems these models now that they are a couple years older tend to break the screen hinge somehow. Would love some help or suggestions on at least where to find a part to fix with.
Это хороший вопрос?
Оценка 6
Добавить комментарий
2 Ответов
Выбранное решение
Hi @jjtortilla ,
Here is a link to the service manual for your laptop.
On p.57 you will find the necessary pre-requisite steps and then the procedure to remove the hinges.
On p.73 you will find the part numbers for the hinges (item #9) and the LCD cover (if necessary - item #10). Search online using the part number only will give you results for suppliers of the part.
Hopefully this is of some help.
Был ли этот ответ полезен?
Оценка 6
1 Комментарий:
Thx a bunch man. This is a lot of help.
из
Jayeff’s answer was great. I had a detached hinge (the glue between hinge and back of display failed), and decided to re glue it. I sanded the surfaces to be attached with 80 grit sandpaper and epoxied them together. No need to replacement parts.
Just in case it’s helpful to others, I’ll add to the answer above in that:
  • I think the prerequisite steps are pretty much necessary (event though i would’ve like to because the hinge is sort of hidden under everything.
  • Make sure that the hinges are well aligned so as to prevent any extra tension in the hinges. I did the alignment by temporarily attaching the hinges to the base and then marking where the hinges would sit on the display’s back with a marker.
Now let’s see how long this lasts. I used “Bostik’s Epoxy Rapid 2 Component Epoxy”.
Оценка 1
2 Комментариев:
Thanks, I will try this repair! How does your hinge hold up after 6 months?
из
Any updates? Did your epoxy hold up? I've seen this fix several places online but no one has updated after a year or more. :(
из
Добавьте свой ответ
Daniel Collins будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 4,077
