Stage Light Effect on Display Screen
With my horrendous luck I noticed this issue just a week after the 1 year warranty of my Macbook Pro ended.
According to my research this issue can stem from 3 things:
1) a faulty LED-Backlit display in which case will need to have the whole display replaced
OR
2) LVDS 'graphic cable' issue, either it needs to be
--replaced
--or just repositioned
At this point in time I'm leaning more towards bringing it to an accredited Apple center for repair.
My question is, can anyone tell me the range for fees and for how long the repairs would be for each scenario mentioned above? Just a minimum/estimate would be fine so that I won't be quite shocked when I do bring it over to the center ><
And is this an issue that I can just ignore, practically speaking? Would it get worse if I leave it as is(like bigger shadows or whatnot overtime)?
On a side note, I also noted keyboard issues popping up after this. Sometimes the letter 's' would have a lag, won't be functional or would double type. Same with the no. 2 key. I'm not sure if this is related or an entirely different problem with the display -- no other functions seem affected
MacBook Pro (13-inch, 2016, Two Thunderbolt 3 ports)
Processor: 2 GHz Intel Core i5
Memory: 8 GB 1867 MHz LPDDR3
Graphics: Intel Iris Graphics 540 1536 MB
- picture taken at the lowest screen brightness
- increasing it appears to lessen the shadows but they're still visible even at maximum brightness
Это хороший вопрос?
FYI - The cable is just called a display cable now as the signaling is no longer LVDS it's now using internal Display Port (iDP). All Retina displays use this newer signaling method.
из Dan
Please sign the petition https://www.change.org/p/apple-fix-all-m... to let Apple fix such faulty machine. I am also facing this problem.
из Ashvin Suthar
I am also facing this problem, contacted apple support and they told me to get it fixed by a third party. Don't do this! because if you do and they acknowledge this hardware problem you won't get a refund.
из Anton
I have the same problem.I wrote the Apple Support.But Apple says I need to replace new screen and it is approximately 650 US Dolar.I can’t afford it and I don’t want to pay a lot of money for Apple producing faulty.I don’t know what I will do.
из mehmet ali ersu
Join the club! #flexgate
Sadly there are no options ;-{ You need a new display assembly! I would get to an Apple Store and press them on the fact this is a product defect!
The Design Flaw Behind MacBook Pro's 'Stage' Light Effect
из Dan
Показать 5 больше комментариев
