Where is my fuel relay located?
Trying to replace my fuel relay for my truck and I can't find it. My truck used to run. Now I turn the key, it engages the starter but I don't get any fuel to the motor. I've replaced my fuel pump, fuel filter. Now it's down to either the worse for the pump or the relay. So I'm doing the relay.
Это хороший вопрос?
Оценка 1
1 Комментарий
Did you fix it if so how?
из
Добавить комментарий
Ответов (4)
Выбранное решение
Hi @skittleman88 ,
Not sure if this is relevant to your vehicle, but here is the service manual for a 1985 Toyota Truck - 4 Runner.
In the FI section it details the EFI system, including the electrical circuits. (see FI-65)
Был ли этот ответ полезен?
Оценка 4
Most likely under your bonnet (hood) will be another fuse/relay box. Look on the cover or inside the cover and it should show you the relay number. To test it just pull another relay that has the same ratings and use it. If it works it is your relay, if it doesn't work. Not a relay problem. Do you hear the fuel pump prime when you turn on your ignition? Have you checked your fuel pressure if injected?
Оценка 2
1 Комментарий:
thank you, for your time.
из
it's at the kick panel fuse box located driver side floor behind the panel
Оценка 1
1 Комментарий:
ok i have no covers thank you for your help
из
im not much help my problems with this 1985 fuel injected 4 by 4 the wiring harness is out of a 1988 22re 4by4 and motor it has been difficult to put the to together
Оценка 0
Добавьте свой ответ
William Ingram будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 3
За последние 7 дней: 15
За последние 30 дней: 72
За всё время: 13,481
