Is it worth it to replace battery on iPad 2?
DISCLAIMER: I haven't found any simmilar article about this question on this forum.
is it worth it to replace a battery on iPad 2? There are problems with iPhone's batteries that result in forced performance reduction, but i haven't found any confirmation about iPad(s) which should had same batteries.
Can you confirm it?
If that's a case will it solve new battery from ifixit? Won't it just delay same problem?
I'm android/linux/windows user. This device was a gift from family so i don't have experiences with Apple Products.
it was useble and pretty cool at first, but then it got iOS updates and i notice performace drop from IOS 7~NOW. Could it be a problem with just battery? Or should i downgrade/look for cydia solution/Different OS for it too?
Is it worth it to modify this device somehow? Like solder better chip, modify its frame to hold custom batteries, (custom cooling solution), etc.. ?
I want to use this device for graphic design nor project management using custom software.
Thanks for any help! :)
Это хороший вопрос?
