Asus Q534U is part of ASUSTek Computer Inc. Q-series laptops. The laptop has a 360 degree folding hinge that allows the device to change between laptop and tablet by a simple fold.
23вопросов Показать все
How do you disassemble the monitor lid on an Asus Q534UX?
I have no video on my Asus Q534UX but do have backlight. The computer does work with an external video display, so there is something wrong internally. I have another similar laptop (q534u) which I want to try swapping parts such as cables and lcd screen to identify the bad component for replacement but do not see how to open the screen itself. How does it open?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
I have the Q524U Flip Laptop. To open mine you have to unscrew the hinges and then with and shim, razor blade knife, or anything flat; pry the lid and screen apart. You'll have to use a little force but dont worry since the lid is aluminum. After you get those apart you should be looking at the internal of the LCD. Hope this helps
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Keith Elkin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 708
