The Samsung Galaxy S6 Edge+ is the larger variant of the Galaxy S6 Edge smart phone.
99вопросов Показать все
Screen broken, stays black
I was on my laptop and I looked at my phone and I saw a row of pixels just black out, and after that they started flickering. So I put my phone away and I looked at it again and when I pressed my powerbutton and the lower side of the screen started flashing. Now it's blacked out and when I slap on it and then it works, but when I move it for just a centimeter it blacks out again. and it starts flickering on the lower side. My upper side is totally blacked out. But sometimes my screen lights up, but the lower side has a white glow over it. And the row of pixels that is gone keeps being visible. How can I fix this?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
It sounds like a damaged LCD. I would take that in to be serviced or, if you're feeling capable enough, you can replace that screen. I would order one with a midframe as it makes the entire repair a lot easier. Just make sure to take your time. If you're feeling like you wouldn't be able to successfully do that, any Samsung certified repair center can replace that screen with an OEM replacement and have you up and going!
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Joep будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 264
