hi i am a 79 year old scottish man, i have the same problem.
1- do not concentrate on that mickey mouse red switch because that is not the problem.
2-take some dish soap and a toothbrush on clean all around the rubber gasket.
3-try and pull on where the rubber gasket is all the way round
you will probably see a part of the gasket that wont move at all and thats why it will not open.
put some water in the sink with some dish soap with ,just enough water to cover the gasket
leave in in the sink for about 5 mins. take it out and pull on the sides of the gasket to loosen
the gasket it probably pretty nasty inside keep pullin all the way around the gasket’
once you have done that and got it all loose then push on the red switch on top(mickey mouse)
pushing on the gasket at the same time
4- once you have done all that and it is open. then keep opening & closing it. you will have to
push on the bottom at the same time as you are pressing the red button
on a lighter note once a king always a king once a nifgts enough ha! ha! ha!
we all need a sense of humor at this stage of time. good luck you probably not need good luck
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
20 Комментариев
I also have a Dyson V8 absolute. The mechanism / red handle to open the bin is stuck. Having a new replacement bin is not helpful as I cannot access the bin release button to replace. I believe this is similar to the original authors problem. I have had it for 2 years with no problem so am used to the motion and strength required to empty the bin. The red handle now feels stuck and applying excessive force will break /snap something
из colin chan
I took mine back to the service dept and they told me I shouldn't shut it by firmly by putting it on a hard surface to" click" it into place. Softly softly they told me. So far so good, but I am not holding my breath as this is the third time being serviced within a year.
из Linda Lang
Thanks Linda, i'm on the hotline hopefully to resolve , use mine once a week for two years. First problem i have had to be fair. CC
из K S
Problem fixed, appears the jam happened because the bin was closed shut before you push the cyclone down. In other words closing the bin door is the very last thing you should do. You can press the red paddle/button on the very bottom and ease the bin out manually, it is quite stiff so you need a good wiggle to get the bin off. Then the cyclone was no longer stuck and the bin refitted.
из colin chan
You are 100% right Colin. Why the service dept couldn't have told me this the first time puzzles me.
из Linda Lang
Показать 15 больше комментариев
