Heat accumulates as electricity passes through the various components of a computer: processors, drives, etc. Most computers will be designed with mechanisms for removing the heat so that it does not damage the components. Part of the thermal management design is monitoring component temperature and if it gets so high that damage may occur, a switch will shut down the computer/device.
Passive thermal management includes methods that utilize unassisted airflow through the device. Usually the device has openings in the base through which ambient temperature air is drawn. Because of this, it is essential to have adequate clearance between your computer’s base and the surface it sits on, or a perforated stand allowing for air movement, for air circulation sufficient for cooling.
As the air next to the components is heated by them, since hot air rises, it passes up through vents in the top of the device. This also sucks in air through the vents in the base. Another passive management method is to use a heat sink, usually a significant mass of metal, often molded with fins. The mass absorbs the heat from components by direct contact. Where the metal mass abuts the component, usually a processor, thermal paste can help bridge any gaps in the contact and facilitate heat transfer to the heat sink.
While heat sinks pull heat away from components, they also must have a way to get rid of that heat so it can continue to absorb it from the components to keep them from overheating. This is typically done by transfer of heat from the heat sink to the surrounding air; increased air circulation for significant cooling, is usually enhanced with fans. You can purchase additional fans and you can run the fans at a higher speed. You can also buy fan speed controllers and sometimes a simple software program to increase fan speeds.
There are also more complex (and more expensive) methods of cooling electrical components such as water-cooling and the use of piezo-electric devices. Less complex methods include lowering the ambient air temperature of the room you’re using, and elevating the computer inches off the surface it sits on and placing a small, portable fan behind the computer to facilitate airflow up through the base and through the computer. Another quick and easy fix for overheating is to go to your Power Saving Controls and set processor power consumption down from 100% to 60-80%; less electricity use means lower heat production.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
1 Комментарий
How did you open your ps4
из Visualz Windex
