Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
58 Questions Показать все
transmission oil ford ranger 2008
After 65k miles can I change the transmission oil since I have not changed it before without negative results?
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
1 Ответ
Наиболее полезный ответ
william rios according to the Ford routing maintenance manual:
at 30,000 miles vehicles equipped with the TorqShift transmission and the externally-mounted remote filter element, replace the automatic transmission fluid and the externally-mounted remote filter element (if equipped). Inspect automatic transmission/transaxle fluid level on all other vehicles if equipped with dipstick. Consult your dealer for particular requirements.
at 60,000 miles change automatic transmission fluid on all vehicles equipped with the TorqShift transmission. Replace the externally-mounted remote filter element for all TorqShift transmissions (if equipped). Replace the internal TorqShift transmission fluid filter located inside the transmission bottom pan (vehicles without externally-mounted remote filter only). Inspect automatic transmission/transaxle fluid level on all other vehicles if equipped with dipstick. Consult your dealer for particular requirements. at 60,000 miles.
I am convinced that your transmission is going to be fine with an oil and filter change.
Был ли этот ответ полезен?
по рейтингу 1
Добавьте свой ответ
kmaleon будет вечно благодарен.
Просмотр статистики:
За 24 часа: 3
За 7 дней: 8
За 30 дней: 27
За всё время: 766
