Кофеварка, выпущенная в 2013 году.
Need disassembly instructions to replace Keurig K70 air pump
Partial cups of coffee. Done the easy and usual: clearing the puncture pins of debris, filter at bottom of reservoir, descaling with vinegar. Now I am convinced it has to be a weak air pump.
I'm looking for a way to remove the guts to get access to the air pump. I'd like the results to be cosmetically pleasing, so the hacksaw solution is not acceptable.
Это хороший вопрос?
Счет 2
3 Комментариев
I have the same problem? Any answers yet?
из Поделиться
Sorry to say, I put that Keurig in a bag on the shelf in the garage awaiting some further inspiration. I have not had progress, other things became more important. Probably end up buying a new one…. I have been using a smaller Keurig labeled with Mr Coffee logo and that one, too has started has started to make 1/2 cups… Common fixes don’t work for that one any longer Gee Whiz….
из Поделиться
Nobody knows how to take a keurig apart? I might as well tinker blindly! Will post if I have any luck.
из Поделиться
Добавить комментарий
1 ответ
Наиболее полезный ответ
Here’s a video on how to fix it:
xhttps://www.youtube.com/watch?v=CuczMT3R...
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Been there and agree that’s the problem, but there is no instruction about how to remove the guts to expose the air pump for replacement!
из Поделиться
Добавьте свой ответ
Eric Andersen буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 21
За все время: 1,938
