Why wont my ps4 show up on my tv?
My ps4 hasn't been working for two days. I have tried 3 different HDMI cables, two tv's and it still wont work. Safe mode isn't coming up but my tv does recognize its connected to a playstation. Their is also sound coming through my headphones when connected to my controller. The light shows itstarted properly (blue light then white light). what should I do?
Это хороший вопрос?
65 Комментариев
When you say safe mode isn't coming up, have you attached your controller to the PS4 via a usb cable? As that is the only way to get safe mode to start.
из sm_vulkus
I had the exact same problem. I unplugged the ps4 for 24 hours and connected the hdmi into another port before turning it on. It worked! I then powered it off and then connected the cable back into the original port and it still worked. Not sure if it had something to do with the amount of time I had it unplugged or if it was switching ports.
из Curtis Griffin
My question is, my ps4 does this but only for one tv that I own, I’ve hooked up other things to the tv via the same HDMI cable and port and they work perfectly, I’ve also hooked up my ps4 to another tv in my room with no problems via HDMI so I know it’s not my ps4 either
из Chandler Rayborn
Mine suddenly started doing this also !!
из danieltapp
I have the same problem, but you have solved the problem.
из Damjan Forjanic
Показать ещё 60 комментариев
