Will Drain but Won't Spin
I have a Kenmore Washer model number 110.21302010. It will get to the final Drain/Spin part of the cycle and will drain and drain and drain (I can hear the motor trying to suck out all of the water) but it won't ever spin. Clothes are wet. I've tried going to the Rinse/Spin cycle as well as the Drain/Spin cycle and it never gets to spinning.
I recently had the same problem but the washer was able to spin if I used the Rinse/Spin or Drain/Spin cycles. I ended up replacing the Actuator and it worked for about a week or so and I'm now having the same problem but it won't spin at all (it will agitate during Wash and Rinse cycles).
Anyone have any ideas?
Это хороший вопрос?
I have this problem as well. There is no telltale sign that the washer is malfunctioning, but all it does is drain the water - no spin action at all.
I find that if I manually turn the tub about 90 degrees and restart the spin cycle, it will then work properly. Any ideas on what the solution might be?
из Mike
