battery wont hold charge
Replaced battery, If truck sits more than a day or so , it won't start. Had Battery, starter and alternator checked all OK. What should I do next?
Это хороший вопрос?
Это хороший вопрос?
Hey Jomozolo,
I had this problem before and did just as you did. I ended up following the wires everywhere and testing each one and found there was a bad ground (on my fuel pump if memory serves me right) that was absolutly draining my battery! After fixing this, my truck ran just fine. It could also be some bad corrsion on a connector if your from the Northern states. I hope this helps out!
-Arch
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 317
