Stalling after tune up and changing mass air flow sensor
Это хороший вопрос?
Это хороший вопрос?
Did you scan your car prior to installing the MAF to make sure that was the actual problem? Or is it was a mechanic did you see the print out? Then after installing the part, did you clear the codes, test drive and check to see if new or same codes came back?
MAF sensors are very fragile, and can be easily damaged during install by being rougher than necessary.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 418
Did you replace the MAF with a Nissan part, or an aftermarket one?
из JONATHAN R FISHER
