Steam-контроллер Valve, выпущен 10 ноября 2015 года. Модель 1001.
Button stuck down how can I clean this
I have sibling who spilt coke on my controller everything else works except b button is stuck how can i clean it the easiest .
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (3)
Выбранное решение
two options.
the best of them is to open it up, and clean it out by disassembling it, then scrubbing it with a 99% isopropyl, and a toothbrush.
the other option is to spray it with a deoxidizing electronics cleaner, and let it soak, then scrub the button with the same isopropyl stated above.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Thanks this fixed my controller and buying 99% isopropyl is cheaper then a new controller
из
happy to have helped. i do this every day for my customers. saves a lot of money than replacing.
из
First, you should do the obvious; if you haven't already you should wiggle the button around in order to get it loose. I'd also blow it out with canned air, you should be doing this on a regular basis anyway.
If all else fails, you may have to disassemble the controller and clean it from the inside.
Оценка 1
I've disassembled mine and found the rubber tactile mesh has snapped :(
Can't find a way to buy spares anywhere...
Оценка 0
Добавьте свой ответ
Damon Diller будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 6
За последние 30 дней: 23
За всё время: 4,536
