An E-Cigarette vaporizer is a device used to heat a substance, such as cannabis or tobacco, to a temperature at which it releases a vapor that can be inhaled. It is a reusable alternative to traditional smoking.
Smok T-PRIV 3 bricked, need 1.0.1 firmware
My Smok T-PRIV 3 got bricked, was wondering if anyone who has one could somehow extract their firmware and send it to me. Smok doesn't have the firmware for it on their site for some reason and I am out of luck. Been trying all day to fix this thing.
Это хороший вопрос?
Оценка 10
23 Комментариев
Have you got your mod fixed yet?
Have you found the firmware? I haven't had any luck in my end. Even after emailing the company I haven't received a response yet.
из
thanks man, ive been trying for a month to get this from smok.
из
Worked for me
из
I was able to get my T-Priv 3 back to operating. Though mine is doing this weird thing now when I take the batteries out it won't retain my previous configured settings. It drops the Puffs back down to 0 and everything. Thoughts?
из
Показать 18 больше комментариев
Добавить комментарий
Ответов (13)
Выбранное решение
Here's the Stock firmware hex file:
http://www.filehosting.org/file/details/...
Был ли этот ответ полезен?
Оценка 3
7 Комментариев:
Dude thanks so much, Smok support wasn't doing anything. Gonna search around reddit, etc and post this for users that got affected. You saved me another mod.
из
;) I also recieved from a user who succeeded to get a reply from smok support. Still can't imagine how. I also wrote them 3 times but no answer
из
Still can't believe they don't have this posted on their website. Anyways thanks man you made my night.
из
Bosnyák Marcell, tudnál nekem segíteni egy h-priv 2 esetében?
из
Hello nekem egy smok mag om van amin nincs firmware abban tudnál segiteni?
из
Показать 2 больше комментариев
Hello, me when I had my t-piv 3 it was not mark(brand) not for t-priv 3. Of the blow I had made the putting has in the daytime and she does not want to ignite any more...
Somebody would have the firmware of it t-priv 3
Оценка 1
Hey I had this same problem. I took the batteries out to charge them and it wouldn't turn on when I put the charged batteries back in. After some desperate troubleshooting I was able to get it turned back on. I put the batteries in, held down the firing button as I closed the battery door. I saw the led light up and it came back from the dead. Hope it works for you too!
Оценка 0
4 Комментариев:
I have a question, did you try and update the firmware on your T-Priv 3? If so did you wipe it or just keep the firmware that didn't work on it, thanks.
из
I looked into it and saw the website didn't have a link for the T Priv-3. It specifically says not for the 3 so I didn't try it.
из
из
Hello guys! I have a h-priv 2, which bricked after updating. Not turn on, and the pc can not recognize it. How could i revive it?
из
I have the same problem i bricked my by trying to update it, where the lights would turn off when the battery's got low to 1.0.8..... After the update i then found out the update was for the T-Priv NOT THE 3. LOL
That was my bad but im in need of the stock firmware 1.0.1.. Please HELPPPPPPPPP lol.
Оценка 0
1 Комментарий:
Hi I have tpriv 3 how can I reset all settings to default
из
Link did not work send me the tpriv 3 link
Оценка 0
Would anyone by chance have the stock firmware for G Priv Baby Luxe?
Оценка 0
Reuploaded if others still cannot download
'''https://multifilemirror.com/3t72qodhtlbf...
Оценка 0
1 Комментарий:
can you post it again please
из
alguien con el firmware para X-priv tengo un problema y necesito actualizarlo, presenta ohm demasiado bajo sin el atomizador, gracias
Оценка 0
1 Комментарий:
los capacitores de salida estan en corto e.e estudia electronica
из
Hello guys! I have h-priv 2, which bricked after updating it. Not turning on, and pc can not recognize it. How could i revive it? Please help me. Magyarok , ha van hozzá értő, kérem segítsen!
Оценка 0
Hi guys I have a smok t-priv 3 everything seems to be working fine except the green led lights stay on even when shut off does anybody know how to fix this situation
Оценка 0
My t-priv 3 the light is red even when off and will not turn off!! It hits and works right but I’m to afraid it will blow up! Something ain’t right if you figure it out let me know to! I’ve had to buy like four new vapes since this happened! And I paid top dollar for it!
Оценка 0
Where can I find the smok t-priv users manual
Оценка 0
Can anyone tell me where to get stock firmware for the g priv 3?? I dropped my mod like 3 inches in a golf cart now the screen is black and it won't fire!!! I thought if I reset it, it might reboot???
Оценка 0
Добавьте свой ответ
iWoundPwn будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 28,642
