7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220вопросов Показать все
My ipad won't turn back on after charging to 100%.
My iPad works fine until I charge it to 100%. When it gets to 100% it will take days for it to turn back on. I've tried different sockets, plugs and I've tried hard resetting it. Sometimes it will turn back on after a few days but now it's not coming back on.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
I'm curious...when it eventually does turn back on, is the battery still at 100% or has it lost some charge?
I have not seen this problem and other than the battery or a logic board issue, I can't imagine what could cause this. Next time the iPad is functional, try testing the battery health with a tool like coconutBattery (Mac) or 3uTools (Windows). If it is anywhere below 60%, you should change your battery.
If a new battery doesn't help, then it is probably an issue with the logic board.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
When it turns on it is back at 100% but I have to leave it on or use it for a bit so that it loses a little bit of charge otherwise it will just die again.
из
I have the exact same issue with my daughter’s iPad. The device shows 100% power once we can get it to boot. Once running it can shutdown anytime then take 1 to 5 days to restart. I just bought a battery replacement kit from Ebay and will let you know if this fixed the issue. I know this post/question is from 2 years ago but I just wanted to update other people on what may fix or not the issue. Thanks
Оценка 0
Добавьте свой ответ
Deanna Mathieson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 1,867
