The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
171вопросов Показать все
Why can't I get my disk out?
I can open the disk drive just fine but the disk is, most of the time, stuck inside & has to either be pried out (which scratches the disc beyond repair) or I have to take the entire X-Box apart and take apart the disk drive to get the disc out safely. What is wrong and how do I fix it?
Это хороший вопрос?
Оценка 3
5 Комментариев
Melissa, it happens all the time with every disk?
из
Yes with every disk. Thanks for the website
из
try the alignment it does sound like your drive is on its way out.
из
Now it flashes orange and green when I turn it on :(
из
Nevermind, once I plug it into the TV its fine. Thanks. The other site is very helpful too!!
из
Добавить комментарий
5 Ответов
Выбранное решение
I would try with alligning the disk tray and to make sure there is nothing inside the drive :-) check on Llama.com for any further help with your Xbox
Был ли этот ответ полезен?
Оценка 5
2 Комментариев:
+ A lot of good tutorials there.
из
+ great resource for xbox problem solving
из
Hi,
You should watch this video
http://www.youtube.com/watch?v=-62PD8SyI...
Xbox Stuck repair ^^
Оценка 1
In the event that the item are unable to study any kind of drives the DISC get is usually cracked; if it is just about several drives after that your computer get is quite vulnerable. Make sure you are merely putting in 360 game titles, Dvd videos and also new music Video games. If you have a hardcore get first video games when its on a single computer next the computer carries a dilemma you can go to the xbox 360 system internet site to see if a computer carries a acknowledged dilemma.
Visit Xmoddz site for more information of this topics.
Оценка 0
all u need to do is replace your small belt on the inside there iv fixed prob .a hunderd like that
Оценка 0
1 Комментарий:
oops read that wrong
из
insert pin/paperclip works every time no harm to disc it's a fail-safe manual open.
Оценка 0
Добавьте свой ответ
Melissa Hine будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 9
За всё время: 4,415
