The MSI GS60 6QE Ghost Pro 4K is a high performance gaming laptop.
7вопросов Показать все
No display on my machine after 2 previous repairs.
My machine is still under warranty.
I've had 2 previous repairs from their authorised repairers.
1st repair: *trackpad stopped working*
Replaced: Trackpad, Trackpad Mylar, Trackpad cable, FPC and battery.
I sent this back as the trackpad wasn't seated properly, and a key on the keyboard didnt work.
2nd repair: *trackpad not seated right, and key not working*
Replaced: MAINBOARD and Battery? *AGAIN*?
Now the machine is powering on (lights come on, fans are on, but no display. Neither on external).
MSI Won't accept a return / replacement or refund as they say it must be repaired 3x in order to have this even as an option.... Is this right?
Kind regards,
Karlan P
Это хороший вопрос?
Оценка 1
Комментарии:
Yeah, that’s correct about the refund, it’s dumb.
I’ve tried all the basic unplug power off nonsense, I’d much rather get it repaired under warranty, let it break again and get a refund haha. Weird system they have
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hello,
You tried to send them again, for the third time ? If I understood correctly, they don't accept a refund because it wasen't repaired 3 times ?
You have any experience in electronics ? take the graphics card and test the capacitors, diodes, mosfets and transistors, probably the graphics card is dead, but you will void the warranty...
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Karlan Parker будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 204
